Jtrux Posted November 28, 2017 Share Posted November 28, 2017 Are you guys modifying XJ inner rockers for MJs? I haven't been able to find an inner specifically for the MJ. Thanks Link to comment Share on other sites More sharing options...
youngfred Posted November 28, 2017 Share Posted November 28, 2017 14 minutes ago, Jtrux said: Are you guys modifying XJ inner rockers for MJs? I haven't been able to find an inner specifically for the MJ. Thanks ... Are you talking about the front, like these ? I picked up a nice set for the front at - J & W - Antelope, CA. youngfred Link to comment Share on other sites More sharing options...
Jtrux Posted November 28, 2017 Author Share Posted November 28, 2017 No, I'm referring to the panel that is wedged imbetween the floor and outer rocker on the can. Thanks, though. Link to comment Share on other sites More sharing options...
90BlackMJ Posted November 29, 2017 Share Posted November 29, 2017 I went through the same ordeal. I almost ordered Xj inners, they probably would have worked just fine. I ended up cutting out a piece left that was in good shape for a pattern and took it to a local sheet metal shop. They are gonna form them up out of 16ga. Link to comment Share on other sites More sharing options...
