AMC86Kid Posted November 20, 2017 Share Posted November 20, 2017 ok so I'm gonna do the vacuum lines today and i was wondering if anyone knows whee the vacuum port on my EGR valve should go ? Link to comment Share on other sites More sharing options...
Marine1Texas Posted November 20, 2017 Share Posted November 20, 2017 the 4.0 goes from egr valve to a electronic valve on the left fender then to the intake vacuum. Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted November 21, 2017 Share Posted November 21, 2017 On the same 2.8? I wouldn’t bother. It’s convoluted routing through vacuum switches, you can probably trace some of it from the pictures in the other thread but.... Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Marine1Texas Posted November 21, 2017 Share Posted November 21, 2017 If you live in a state or area that does not do emissions, or your exempt because of age of vehicle like I am, just leave it disconnected or you can do a delete. Mine is there vacuum all hooked up, however I unplug the electric solenoid plug. passes visual if they ever do it, however does not allow that carbon from exhaust in to the intake system. They say it helps cool the engine combustion chamber. Mine has never had any effect from leaving it unplugged . Link to comment Share on other sites More sharing options...
AMC86Kid Posted November 21, 2017 Author Share Posted November 21, 2017 well i have to hook up the charcoal canister to something so i guess i will do it like this run vacuum line from here: to here: then i got to figure out how to get a timing tab on the motor so i can set the timing right with a light-gun and of course see it it still over heats or if the new head gaskets fixed the problem Link to comment Share on other sites More sharing options...
