I'm guessing this has probably been covered, but with the photobucket BS it's hard to find a picture. When mounting the new steering column brace, do new holes need to be drilled in the kick panel area or can the existing holes be reused?
I'm not talking about the steering box, when doing the 97 swap you remove the renix dash and Steering column mounts. The 97+ uses an actual bolt on brace, I need to find out if existing holes will work or if I have to drill new ones.
