mvusse Posted September 29, 2017 Share Posted September 29, 2017 I have more front axles than Jeeps, so this one is not needed. $150 firm. -High pinion front axle, complete brake rotor to brake rotor. -Will fit 86-92 MJ, 84-01 XJ Cherokee, 93-98 ZJ Grand Cherokee, 97-06 TJ/LJ Wrangler. -4.10 gears. in an MJ/XJ 4.0/auto this ratio will give you correct speedometer reading on 33" tires. -Open (No limited slip or locker) The good: -BRAND NEW BALLJOINTS, ALL 4. This is $251.96 plus tax just for the parts. -brake pads have 3/4 material left -No play in the unit bearings -Large U joint shafts with Spicer non greasable u joints -Calipers worked fine when I removed the axle a few months ago. The bad: -Loose lug nuts messed up the studs on the driver side. One has broke off, all 5 need replaced. These cost $2.49 each at Autozone, so $12.45. -Brake rotors have rust from sitting in the weather. Driving a few miles should clean them up, or you can have them turned or replace them. $150 firm, will deliver within reason for $1 per loaded mile from Strasburg, OH, 44680. Link to comment Share on other sites More sharing options...
TheDude Posted September 29, 2017 Share Posted September 29, 2017 Would you meet part way to Pittsburgh?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mvusse Posted October 2, 2017 Author Share Posted October 2, 2017 Sure. How about the Wendy's in Cadiz (junction of US-22 and route 9/Lincoln Ave)? Link to comment Share on other sites More sharing options...
Archived
