Green Mesa XJ Posted September 14, 2017 Share Posted September 14, 2017 That is the place. These cylinder heads i am using heads are 85-95 2.8 to 3.4 heads. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 14, 2017 Author Share Posted September 14, 2017 Ok so I can get a temp sensor and screw it in that's not a problem but how does the temp gauge in the dash work or how can I install a new one to the sensors I have do you think I should start a new post on "86 temp dash gauge how does it work" Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 14, 2017 Share Posted September 14, 2017 Not sure what you mean. If you have a sensor for the gauge package, you should just need to hook that one red wire to it. They are dead simple, just oddball part # because the 2.8 is oddball for jeep and Chevy before the changes in 1987. The early coolant sensor for the cluster 2.8 and 4.0 (2.5??? Not sure) are in the drivers side of the cylinder head, one wire connection with the engine acting as ground. Later 4.0 XJ (1996 up) move to one sensor in the thermostats housing with the OBD II computer feeding data for the gauges. I think you are close to getting it working, if the parts numbers I gave are worth anything, which I'm not 100% they are. I know the aftermarket parts especially for small parts have been off for that jeep for the 20 years I've had it. This fiero group has a chart that should work for testing the sender outside the engine http://www.gafiero.org/bbs/index.php?topic=641.0 far as creating a temp switch combination for the electric fan I'm not sure all the steps for that. It's going to be a separate wiring job because the 2.8 harness will not have a plug and play solution since it was a mechanical fan. The s10 forums will probably have the answer. But the correct sender in the intake like you've been doing will probably be the key for that. Probably a kit for it someplace. Edit : here is one solution for the electric fan, he used a generic kit Hayden 3647 http://www.s10forum.com/forum/#/topics/495062 Edit: seems Hayden's quality has slipped jegs kit 10560 is probably a better choice. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 14, 2017 Share Posted September 14, 2017 BTW if that sensor you bought is a alternative for 213-80 it should thread into that spot on the cylinder head. A guy with a firebird had the same trouble finding that sensor said it was replaced by gm 8993146, used in a lot of gm motors 78-late 80's. You might also look up 78 Camaro 5.0 temperature sensors for some other possibilities. Unfortunately I don't see threading size listed online. If all else fails maybe try a beck arnley 158-0536, it's a new style two prong sensor with plug pigtail. So should just need to wire up the hot side of it since it's already grounded. It'll be a kluge fix but... Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 14, 2017 Author Share Posted September 14, 2017 ok so i connected an ohm meter to the new sensor and its telling me around 1580 ohms which is around 100 degrees so my sensor is working properly but my gauge is not when you say "one wire connection with the engine acting as ground" do you mean that the gauge is connect to the engine and the red wire to the sensor that might be my problem i may not have my engine grounded properly i have the negative terminal connected to the engine from the battery but shouldn't i have some wire from the firewall connected to my engine do you know which one or what color wire should be grounded to the engine if the gauge works on resistance from the sensor i have to have it connected by at least two wires so far i can only confirm that the red wire is connect I'm not 100 percent sure on how its grounded to the motor Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted September 15, 2017 Share Posted September 15, 2017 There should be a grounding strap to the firewall. They usually rot out long before now, can cause some trouble but I wouldn't necessarily think that why the gauge isn't working. Plenty of choices for replacements. If the sender is in the cylinder head it should share the ground. Maybe the wire is bad, but seemed to send a signal when it was hooked up wrong.Or the sensor is bad /wrong. Not sure. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
AMC86Kid Posted September 15, 2017 Author Share Posted September 15, 2017 ok i have started a new post since this is a new topic maybe someone else can help us https://comancheclub.com/forums/topic/53897-1986-28-water-temp-gauge/ Link to comment Share on other sites More sharing options...
Marine1Texas Posted September 15, 2017 Share Posted September 15, 2017 Yes 20% coolant and 80% water is what I meant Link to comment Share on other sites More sharing options...
