Rear Axle Question
Hey Guys,
I'm just trying to gather some more information about rear axles for my mj build.
  If going with a spring over axle setup the spring perches are 42" center to center? right? The Cherokee for example (the 8.25 rear axle) is 44.5" center to center on the spring perches, or is it the same as the Comanche at 42"?
Correct me if I am wrong.
Also I would have to fab a new shock locations for a SOA set up? Would the upper rear shock mounts provide an ample amount of flex and ride comfort if I move the bottom ones around? Or should I do them tilted towards the inside of the bed / \ <<< like that?
