I have looked off and on for a OEM antenna replacement for my Comanche, the aftermarket one is garbage I have on there now.  Does anyone have a source I can look?
Sorry that's going to be junk yard only unless you need a power antenna. I needed the rubber grommet the antenna wire goes through the kick panel, hunted and hunted trying to find the complete antenna assembly because that grommet is only available with the antenna.
eBay may be an option, maybe one of the member here might have a spare.
Sent from my iPhone using Tapatalk Pro
