willi2ds Posted July 7, 2017 Share Posted July 7, 2017 I'm replacing the clutch slave cylinder and the grommet that holds the 2 lines in place where they come through the bell housing crumbled into little pieces. I can't find one anywhere, I've hit the local yards and no luck there. Does anyone know where I can get one? Thanks. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Crash Posted July 7, 2017 Share Posted July 7, 2017 You could probably make one out of similar material. Otherwise, I will be doing a 4wd swap on my MJ soon and if it is intact can send you the one from my factory pukegoat Link to comment Share on other sites More sharing options...
willi2ds Posted July 7, 2017 Author Share Posted July 7, 2017 Yeah, that's kinda the direction I'm heading. I've got some old grommets around here that I'm sure I can rig up. If nothing else it'll get me by until the right one comes along. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
MuddFoot Posted July 8, 2017 Share Posted July 8, 2017 Goto harbor freight and buy the grommet set I've used it alot like 5 bucks Sent from my Z981 using Tapatalk Link to comment Share on other sites More sharing options...
