EGR Problems - 1989 Jeep Comanche 4.0
Hey everyone, I am trying to diagnose my EGR system for potential problems since my Jeep has a very low idle. My EGR valve works properly when I disconnect it from the transducer and apply vacuum to it. My transducer does seem to restrict vacuum to the EGR at idle, but the transducer does receive vacuum from the other end. I pulled out the EGR solenoid and ran some wires from the battery to the prongs on the connecter. When I touched the prongs I did not hear the solenoid move. My question is as to whether a bad EGR solenoid would create a vacuum leak and a resulting low idle. Thanks for any replies.
In my reading, the solenoid is normally open. It is closed upon a signal from the ECU. So I'm believe blowing through it doesn't prove anything. HOrnbrod may have been referring to a multimeter reading of open (no continuity).
Wouldn't a vacuum leak cause a high idle, not a low idle?
Somewhere on the site is a link to the Renix Fuel Injection manual.
It is located here from BioTex
http://www.alpinefurniturestore.com/JeepDocumentation/MJs/Jeep_Renix_Fuel_Injection_manual.pdf
Edited by SVPete
