SBpunk Posted June 15, 2017 Share Posted June 15, 2017 Any suggestions for getting a sandbox full of river sand out of the frame? Pulled the gas tank the other day and there's an inch of sand in the frame and its wet. Don't want it to lead to frame rot and was hoping you guys have some suggestions? I'm pulling the bed shortly but its sealed across the top. Link to comment Share on other sites More sharing options...
Tex06 Posted June 15, 2017 Share Posted June 15, 2017 Pressure washer or hose with a nozzle? Just fish it up there and let it run for a bit. Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
SBpunk Posted June 15, 2017 Author Share Posted June 15, 2017 That's what I was thinking. Running a hose with some pressure to it and putting the front on blocks or something to raise it up. The back ends are open and should drain Link to comment Share on other sites More sharing options...
Airborne Janitor Posted June 15, 2017 Share Posted June 15, 2017 There are holes along the sides of the frame rails that are just big enough for the tip of a pressure washer nozzle to get into. My MJ was used as a mud truck apparently and has inches of mud caked inside the rails. I plan to pull the bed soon as well to get a better shot at getting it clean. Link to comment Share on other sites More sharing options...
