Removing Manual Door Locks
There is a clip you have to rotate. It clicks onto the rod. Once you unclick it you should be able to rotate it and then push the rod out of the hole. You should remove the door panel and even the window to make it easier. I just replaced mine and it was easy enough with them removed.
