Wiggilez Posted May 4, 2017 Share Posted May 4, 2017 When I removed the flex plate off of my donor motor there was a thin spacer between it and the crank, do i need this spacer when i install my flywheel? If you guys want/need a picture of what I'm talking about let me know. Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted May 5, 2017 Share Posted May 5, 2017 Not sure if you're doing a conversion but you should reuse that spacer, if it's just a flexplate swap you're current plate probably has the spacers I just use them instead . I think my 95 motor from a junk yard had two spacers front and back of the flex plate. I figure it help keep the flex-plate in the right position for the CPS or something. Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
Eagle Posted May 5, 2017 Share Posted May 5, 2017 Are you replacing the flex plate, or changing to a manual transmission with a "flywheel"? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 7, 2017 Share Posted May 7, 2017 A flex plate is thin, <<1/8". Having a spacer/washer diffuses the force of the mounting points so the flexplate doesn't over stress and crack around the bolt holes. A flywheel is thick cast iron, you could probably hold it on with 3 mounting bolts, securely, but don't. It does not need anything to balance the torque between bolt holes. Also, the flexplate bolts are going to be shorter than flywheel bolts. Different animal. If you're going from auto to manual you'll be using a flywheel. If you're going auto to auto, keep the washer and use it on a flexplate. New flexplates don't come with the washer, flywheels don't need a washer. Link to comment Share on other sites More sharing options...
Eagle Posted May 7, 2017 Share Posted May 7, 2017 When I removed the flex plate off of my donor motor there was a thin spacer between it and the crank, do i need this spacer when i install my flywheel? If you guys want/need a picture of what I'm talking about let me know. I'm pretty certain you are referring to part number 20 in the parts manual illustration. It's called a "reinforcement," not a spacer, and it doesn't go between the flex plate and the flywheel, it goes outside of (behind) the flex plate. Link to comment Share on other sites More sharing options...
Wiggilez Posted May 7, 2017 Author Share Posted May 7, 2017 When I removed the flex plate off of my donor motor there was a thin spacer between it and the crank, do i need this spacer when i install my flywheel? If you guys want/need a picture of what I'm talking about let me know. I'm pretty certain you are referring to part number 20 in the parts manual illustration. It's called a "reinforcement," not a spacer, and it doesn't go between the flex plate and the flywheel, it goes outside of (behind) the flex plate. Yup that's it. So it's not necessary in manual transmission application Link to comment Share on other sites More sharing options...
