MuddFoot Posted April 26, 2017 Posted April 26, 2017 i am building another mj and did a soa and i used the stock mounts and flipped the sides. is there a shock that i can use or do i need to mount the shock tab on the axle and use a stock replacement.
WyoCherokee Posted April 27, 2017 Posted April 27, 2017 If you did an SOA, then you got rid of the lower leaf cradles which had the shock mounts on them. You will either need to cut off those studs and figure out how to re-weld them back on to the axle, or get a set of weld on shock tabs, and weld them to your housing, then go flex it out and measure for shock length. You can get Bilsteins in just about any length needed.
