1989 jeep Comanche plus 2 parts rigs. 4500
Mack4194
I'm selling my Jeep Comanche I've slowly built up over the last several years.
1989. 4.0. 5 speed.
It's a metric ton model, I've had over 3000 pounds in the bed on many occasions.
Numerically high gears
Rear end has 9.5 inch ring gear. Disk brakes, air locker.
Front end is the hp Dana 30. Detroit locker up front. WJ conversion with cross over steering using 1.5 inch DOM tubing and 1 ton tie rod ends, slotted drilled oversized rotors and dual piston calipers. Also swapped in a ful length axle shaft and sealed the old air activation system which was prone to failure.
Control arm drop kit, and fully adjustable front and rear control arms.
I've swapped in an aftermarket brake master cylinder and power brake boosted. With all these upgraded brake parts it will lock them up if you need it to, it's been a much safer ride since I did that.
LED lights on custom made front bumper with 10,500 pound waterproof winch. Bumper is welded to frame and made of 5/16 AR plate.
LED's inset into rear bumper as well.
High lift jack mounted on roll bar.
High output Electric fan
Custom made snorkel with many other upgrades to allow water crossings.
Videos of water crossings are available upon request.
Not sure of total Lifted height, my guess is 7-8 inches. We can park it next to the parts Comanche and measure if you'd like. Sitting on 35's.
This was my daily driver until a few months ago. It's non-opped because I didn't want to smog and register again.
Also included with sale are two parts Jeep's. A long bed 2wd Comanche and a mid-late 90's 4wdCherokee. These two vehicles are for parts only!!!
Both these pt's vehicles fire up and run.
Comanche runs and drives, it was abandoned on my property and the owner er told me to sell it. I have no title. tranny leak and an overheating issue at idle.
Cherokee fires right up, was told it has tranny issues. Bought it without papers to use for project with the 2wd Comanche now both have been left on my property.
Moving out of state is the reason for the sale.
Pictures in comments
Sorry for not getting back to you guys. I'm not receiving alerts. I'm in northern CA, about an hour above Sacramento.
I'd like to post pictures but can't figure out how.
Here are some links to some water crossing videos from a year or two back. Truck has a few more upgrades now, but you get the idea
https://www.facebook.com/mack.mcgilvray/videos/767959703222826/
https://www.facebook.com/mandi.j.mcgilvray/videos/10152088366827927/?autoplay_reason=ugc_default_allowed&video_container_type=0&video_creator_product_type=0&app_id=6628568379&live_video_guests=0
Archived
