dante2 Posted March 14, 2017 Posted March 14, 2017 While changing the intake/exhaust manifold gasket on the Comanche I dropped the manifolds and broke a sensor low on the driver side of the block. It has a fuel injector type connector. After searching it comes back as a coolant temp sensor is that right? All of the temp sensors that I can find look like the sensor on the back of the head. Any ideas? If you need a pic let me know. Thank you.
MJCARENA Posted March 15, 2017 Posted March 15, 2017 That is the engine knock sensor. The coolant sensor is in front of it.
dante2 Posted March 15, 2017 Author Posted March 15, 2017 Thank you MJCARENA. That's good news at least I won't lose any coolant with that one.
