That_Creepy_Guy_In_The_MJ Posted March 11, 2017 Share Posted March 11, 2017 Okay here is whats going on, i can upload a video later be more specific but for now i'll try to explain to be the best of my ability. So My alternator pulley is still offset, making a pulley misalignment and causing and irritable squeak that stops after 5 seconds or so. And recently it's been making a weird loud metal clanking noise. Sounds like it's coming from the rear end. And i'm pretty sure i know the answer to another problem. My starting issues. Early today at an intersection my mj died randomly out of nowhere. No bog, no signs of dying. Just simply shut off and i had to roll it a block then fire it up. Ran fine after that. And when it is hot, it doesn't like to start. Or if it's been running then sits for probably 40 minutes it doesn't want to start AT ALL. Any help would be greatly appreciated. I'll post a video sometime after this is posted. Link to comment Share on other sites More sharing options...
Pete M Posted March 11, 2017 Share Posted March 11, 2017 jack up the rearend on stands, put it in neutral and rotate the tires and driveshaft around to see if the noise is anything obvious. Link to comment Share on other sites More sharing options...
