DirtyDeeds Posted March 5, 2017 Share Posted March 5, 2017 ok has any one replaced your door lock cylinders? I'm trying to do mine and it looks like its just a black flat metal clip thing and maybe a c clip holding it in, but its so tight i can't figure out how to get the bastards off!! any tips? Link to comment Share on other sites More sharing options...
Dzimm Posted March 5, 2017 Share Posted March 5, 2017 Use vise-grips to clamp the tab and tap the vise grips with a hammer if need be. PB-Blaster will help break up any rust holding them on. Also wiggle the clip up and down as you pull it back helps. Link to comment Share on other sites More sharing options...
