ok guys I'm going to switch/push button start on my 87 MJ and need a lil help identifying what wires do what. if any one happens to know the color code and what color does what that'd be a big help!! also there's this momentary switch that was connected to another rod on the column that i need help identifying
first the black plug that was in the ignition switch
purple wire
black with white stripe
white with red stripe
red wire
orange wire
17035581_484968278558415_1832467319_n.jp
next the blue connector that was in the ignition switch
green wire
brown wire
yellow wire
then this switch
2 lime green wires
2 white wires
one big brown with black stripe
I'm trying to set it up with 2 switches , one for accessory power, one for ignition power and a push button for the starter, but I'm open for recommended set ups   :thumbsup:
well ive been looking through it for the better part of an hour, ive found the connectors and the coding for the prongs, but it doesn't say what prongs go to what wire and what they are for. it has a general wire color guide, ive kinda pieced a little together though
black ignition connector
Red = battery
orange= fuel pump relay
black= ecu ground/ ecm ground
purple= not sure
white/ red stripe= not sure
Blue ignition connector
Yellow= starter switch
Brown= not sure
Green= not sure
and i still can't find anything about the other rod operated switch that was on the column
