Renix (mostly) Misc. Engine Brackets,Clips. D/FW Area
Kerry
I'm looking for the following parts from a 4.0 XJ/MJ. Most are Renix specific...
1 - The bracket that bolts to the bottom of the tranny bellhousing that supports the exhaust downpipe. This is not the one with the rubber mount that's on the crossmember, This one is on the front and uses what's basically a muffler clamp. These also came on non-Renix Jeeps and are often missing.
2 - The bracket for the heater hoses that bolts to the rear pass side of of the block.
3 - The brackets for the hoses that mounts to the AC compressor. I believe there are two.
4 - The clips that bolt to the rear of the engine and to the head that route the CPS sensor wire away from the exhaust. I believe there are two of these also.
I also need the plastic twist things that hold the relay cover down. I have the cover(s) but no attaching screws(?) to hold them down.
These things somehow seem to vanish over time. Let me know if you have any or all. If you need pictures or part numbers I can provide them.
Thanks,
  Kerry 817 716-8833
Edited by Kerry
  • 1 month later...
No guaranty required nor expected. #1 is by far the hardest to find and isn't so noticeable if I have to fabricate one which won't be pretty.PM Sent!
I failed to mention it but I need more than one of all these items. I have borrowed from my two project Jeeps to use on my two drivers (still only have one #1) and odds are pretty good that my next Jeep will be a Renix and that it will be missing some or all of them. I will update the post as needed when I have them all plus one spare of each. I encourage everyone to pack a picnic lunch and take the family out to your local junkyard for a fun filled day of part searching.
I bought it, had it on my watch list for awhile but had not pulled the trigger. It was kinda pricey but that comes with NOS.
So now I "only" need two exhaust brackets  (#1 on list) plus a spare if possible along with  the other items.
  • 4 months later...
I sent you a PM. Let me know what you got and what you want and I'll try to make it happen.
If this goes through then I will still be looking for one more set,give or take a piece, so if anyone has anything let me know.
Thanks
  • 3 weeks later...
