I recently bought a 1992 comanche 4.0 automatic. it is a 2wd.
I was reading some forums and other info, and by the  looks of it I have a AW4. is this true?
Also, I have a 1994 jeep Cherokee transmission with over drive, would this be a direct swap? as in will it go in without having to mess with the computer and other stuff?
The reason of my curiosity is because my MJ has the shifter on the steering wheel and i am not too fond of that, and the Xj transmission's shifter is on the floor, and I like the idea of having over-drive.
Id appreciate any help.
Your AW4 already has overdrive.  It might not indicate it on the PRNDL, I don't know, I've never owned an XJ/MJ with a column shift.  It's the same transmission as in your XJ, basically.
You can swap a floor shifter in if you pull the shifter, cables, console, etc from an XJ that's configured that way, I believe there is at least a couple writeups here on doing it.
Thank you. :)
