Water leak at sliding rear window
Xdt
Guys,
I found a puddle of water at the rear of tha cab. Removed plastic trim poured water around where the outer glass mounding touches the outside cab and splashed water onto the face of the glass itself (to check the small out there weatherstripping that appears to keep glass in place. Basically water leaks at the molding and weatherstripping.
My questions are:
1) since my glass is in great shape does anyone sell a gasket/weatherstripping kit?
2) If no one sells a kit has anyone used a glass shop to remove/ reuse sliding glass, replace stripping, gaskets/ molding?
3) Is it best to buy aftermarket glass which has the gasket and stripping for shop to install.
Thank you
