Jeepjeff859 Posted February 10, 2017 Share Posted February 10, 2017 Starting a 350 swap on my 1986 Comanche. Last year I swapped in a 4.0 to replace the worn out 2.5 I came across a 4 bolt main 350 cheap so I jumped on it and decided I would start to collect parts to stuff the beast under the hood of the jeep. Below is a list of parts I have gathered so far 1. 1987 4bolt main 350. Replaced rings, bearings , and gaskets 2. TBI system out of a c20, included harness , computer, throttle body and some other parts 3. 2 th350 transmissions , one of them is a 4x4 version but needs rebuilt and the other is a 2wd version that is good to go. 4. 2 transfercases , 1 passenger and 1 driver. Have not decided if I'm leaving the front axle as a Dana 30 or swapping it 5. Advanced adapters motor mounts to swap a 350 into a XJ Still need various parts. Looking for a fully loaded XJ harness to adapt control all of the things that don't go with the engine. Will adapt gauge cluster sensors to read the vitals of the 350. Need a stock comanche fuel tank ( have a fuel cell in the bed but want my bed space back ). Have not thought about exhaust or rear axle . Hoping to find a ford 8.8 or Dana 44. My goal is to build a reliable jeep that does decent off-road. Kind of like overland Will take pictures as I go Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted February 10, 2017 Share Posted February 10, 2017 This is gonna be dope Link to comment Share on other sites More sharing options...
