HO Harness and Electronics interchange with Cherokees?
Hey guys, new Comanche owner here. Been lurking for a little bit but thought I should probably join finally.
Bought a nice 92 Comanche SWB  . :MJ 1: .  for $1200 because it wouldn't pass smog.(built in 91, so no need to get hopes up for it being the last off the line)
Anyways, on to my question. I just found a guy that is parting out a 91 Comanche and only has the engine harness and cab harness left. (already scrapped the truck :fs1: )
-Is the computer and engine harness the same between a HO MJ and HO XJ? Should I jump on this because I won't be able to find another spare easily?
-Are the cab harness between renix and HO MJ's the same or should I jump on the Cab harness?
To clarify, I don't have any wiring issues currently but I want to have spares if they aren't interchangeable since these HO MJ's are harder to find.
Thanks for the help.
I will be sure to add my MJ to the registry as well as start a build thread for it when I am not so swamped with work.
