AMC86Kid Posted December 7, 2016 Share Posted December 7, 2016 Have a 86 comanche 2.8 ltr 4wd automatic when i bought the vehicle it had no 2.8 ltr LR2 motor in it so i put in a 3.4 ltr L32 motor in it I'm trying to figure out how the power steering works if anyone has pics of how the power steering hooks up and what it all connects to would be great i don't know where to connect the hose lines from the P.S. pump but i do have the pump connected to the motor Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 i was able to get the motor in there and running fine but i have no power steering as of right now because its not hooked up if anybody needs any more pics of what i have feel free to ask i will post Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 7, 2016 Share Posted December 7, 2016 This is the supply/return hose hookup for the pump, the hoses go to the steering gear box. Do you have a power steering gear box mounted or a manual box? Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 i have no clue i was trying to learn about how the whole system works with parts and everything then i could go back and see if i have anything missing in my vehicle but i will post a pic maybe that will help you lead me in the right direction if some body could take a pic of theres and show how it suppose to look would be really helpfull Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 ok here are the pics i know the vehicle looks bad I'm just trying to get everything working properly then once its all working fine i am taking it all apart and putting it back in to look nice and clean Under the hood driver side Close up this is the lower part of the steering near the radiator Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 7, 2016 Share Posted December 7, 2016 Looks like you need a power steering gear and hoses to connect it to the pump. I can't see the steering gear box in your pics. Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 can you tell me where the steering gear is located? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 7, 2016 Share Posted December 7, 2016 In your last pic it's the unit the the steering intermediate shaft from the steering column is connected to. That's the input to the steering gear. The output is the Pitman arm (curved piece) connected to the steering linkage. Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 oh ok i found it it was hiding under the smog canister so i have hooked it up the way i believe is correct but i was wondering if i could get anyones opinion on if it looks like i did it right? do i just fill it up with the correct amount of power steering fluid and I'm good to go? here are the pics the whole thing close up of the right side close up of the left side Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 7, 2016 Share Posted December 7, 2016 Plumbing looks correct. Fill the reservoir with PS fluid up to the mid mark on the dipstick, start the engine and check for leaks first. If okay turn the steering wheel from lock-to-lock several times to bleed the air out of the system. You should see fluid bubbling in the reservoir. If all goes well, the bubbling will stop eventually. Top the fluid level off to the "Warm" mark on the cap dip stick and you're done. Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 thanks i did exactly what you said and i was able to get the wheels to turn fully in both directions with very little resistance in the steering wheel I'm happy that it works now i will get working on my power brakes i will start a new post for that Thanks HornBrod Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 7, 2016 Share Posted December 7, 2016 That was fast. No more bubbling in the reservoir? Link to comment Share on other sites More sharing options...
AMC86Kid Posted December 7, 2016 Author Share Posted December 7, 2016 oh yes there is some bubbling going on but i am going to replace the hoses and clean the parts so i will worry about the bubbling later when i rebuild it back together Link to comment Share on other sites More sharing options...
