86 MJ Power Steering Question ?
Have a 86 comanche 2.8 ltr 4wd automatic
when i bought the vehicle it had no 2.8 ltr LR2 motor in it
so i put in a 3.4 ltr L32 motor in it
I'm trying to figure out how the power steering works
if anyone has pics of how the power steering hooks up and what it all connects to would be great
i don't know where to connect the hose lines from the P.S. pump but i do have the pump connected to the motor
i have no clue i was trying to learn about how the whole system works
with parts and everything then i could go back and see if i have
anything missing in my vehicle but i will post a pic
maybe that will help you lead me in the right direction
if some body could take a pic of theres and show how it suppose to look would be really helpfull
ok here are the pics i know the vehicle looks bad I'm just trying to get everything working properly
then once its all working fine i am taking it all apart and putting it back in to look nice and clean
Under the hood driver side
Close up
this is the lower part of the steering near the radiator
oh ok i found it
it was hiding under the smog canister
so i have hooked it up the way i believe is correct
but i was wondering if i could get anyones opinion on if it looks like i did it right?
do i just fill it up with the correct amount of power steering fluid and I'm good to go?
here are the pics
the whole thing
close up of the right side
close up of the left side
Plumbing looks correct. Fill the reservoir with PS fluid up to the mid mark on the dipstick, start the engine and check for leaks first. If okay turn the steering wheel from lock-to-lock several times to bleed the air out of the system. You should see fluid bubbling in the reservoir. If all goes well, the bubbling will stop eventually. Top the fluid level off to the "Warm" mark on the cap dip stick and you're done.
thanks i did exactly what you said and i was able to get the wheels to
turn fully in both directions with very little resistance in the steering wheel
I'm happy that it works
now i will get working on my power brakes
i will start a new post for that
Thanks HornBrod
