88whitemanche Posted October 12, 2016 Posted October 12, 2016 What's up fellas I know it's a long shot but wanted to know if you guys know the measurements for the amc 20 axle shafts?
Marine1Texas Posted October 12, 2016 Posted October 12, 2016 So I am guess you have the metric ton 1986. The metric ton MJ from 86 with the AMC 20 had two shafts Driver side 28.31 and Passenger side 25.31. It is the same as the CJ that they called the wide track from 83 to 86.
88whitemanche Posted October 12, 2016 Author Posted October 12, 2016 Well I picked up the amc 20 from a long bed 2.8 Comanche in a jy, if I recall correctly the mj amc 20 is a one peice design, which is known to be stout, but I am on the look out for for spare axle shafts, but wondered if anyone knew the sizes
Marine1Texas Posted October 12, 2016 Posted October 12, 2016 I recall the Dana 20 axles are thicker then the dana 44's. My old hummer had a hypoid AMC 20.
