schardein Posted October 12, 2021 Author Posted October 12, 2021 On 10/11/2021 at 5:23 AM, WVpioneer_88 said: How are you liking your ox cable locker? I’m building some 44s and was thinking about putting one in my rear axle. I've had a cable operated Ox in the rear D44 since 2006. It's always worked great. I routed the cable carefully and used Adel clamps at a couple points to keep the cable in place. The clamps are loose enough on the cable to allow some movement. I did manage to somehow pinch the cable on the Rubicon Trail in 2019. That made the shifter operation a bit stiffer. I was thinking of replacing the cable, but lately I think it has loosened a little from use, so I'll probably keep running it as is. The front D44 Ox is air operated. I think I posted earlier that I replaced a Detroit Locker with the Ox. It's nice having the option now to be unlocked/locked on the trail. So far it has been flawless in operation. I like the fact that it uses a pneumatic rocker switch, so there are no electrical relays to be a potential problem. I routed the air lines carefully, as any time I've seen an air locker fail on the trail, it was most often because of a damaged line from a sloppy installation. I carry an air line repair kit I cobbled together myself, mostly containing parts I got from Mcmaster-Carr. I don't see as many Ox Lockers on the trail as ARB or factory Rubicon lockers, but everyone I talk to that has one, likes them.
