Whiz Posted August 26, 2016 Posted August 26, 2016 So my water pump bearings are going bad, so since I am changing that I was going to replace the thermostat. After reviewing threads I know to get a 195 thermostat, and as suggested in a Old thread looking for a OEM but I have not been able to fine one. The ones I have found at local parts store, none have the hole/needle. Can/should I drill a hole? Any suggestions on finding a OEM? Thanks, Whiz
Marine1Texas Posted August 26, 2016 Posted August 26, 2016 yep just drill the hole. I drilled one at top and bottom. The hole is only needed for the burping. The system in time will burp its self if you have the bottle Renix.
HOrnbrod Posted August 26, 2016 Posted August 26, 2016 You can get the correct 195* Mopar 'stat from the dealer, p/n 83501426.
