daking Posted August 22, 2016 Share Posted August 22, 2016 I installed all new stuff, Compressor, Condenser, Hoses, O-Rings, Black can and so on... Added oil opened the valves 1/2 way on compressor. Vacuumed it out. Proceeded to fill with Red Tech 12. Low side hits ~100PSI. Way too high High side stays at ~0 or sometimes will goto ~50. I have forced the compressor on, no change. The only thing I can think of is there is a "Valve" or something on a hose on the can, maybe that valve is not getting pressed? What am I missing here? Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 22, 2016 Share Posted August 22, 2016 It sounds like you have the LO and HI service valves set in the wrong positions. When charging, the LO side valve needs to be opened (stem turned cw to the stop) and the HI side valve closed ccw to the stop). When finished charging, detach can fitting from the LO side and close the valve (ccw to the stop) for normal operation. Link to comment Share on other sites More sharing options...
daking Posted August 24, 2016 Author Share Posted August 24, 2016 Thanks for some direction. I tried that, and the compressor locked. With the hose closed, nothing to pull. I thought about it, and maybe I should have had the refrigerant can open? So it can suck from the can? What I figured out on those valves. Fully open (Stem extended), allows full flow through hoses. Fully closed (Stem as short as it will go), closes the hoses and only allows valve. Soo, I was thinking the stems need to be about mid point to allow flow through everything. I know I'm not the only one to fill the AC on these, there must be a read me or video out there, right? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 24, 2016 Share Posted August 24, 2016 Can has to be open. Did you see this? It worked great for me. Link to comment Share on other sites More sharing options...
SBpunk Posted August 24, 2016 Share Posted August 24, 2016 Something I didn't know is the little metal nubs that open the AC system turn the opposite direction (left to close right to open). Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 24, 2016 Share Posted August 24, 2016 Yep, just the opposite of what seems logical to me. Link to comment Share on other sites More sharing options...
