johnj92131 Posted August 21, 2016 Share Posted August 21, 2016 Need to locate a transmission support member for the AX15. Please let me know what you have. Thanks, Link to comment Share on other sites More sharing options...
Siopposition Posted August 22, 2016 Share Posted August 22, 2016 Where are you located? I have one that will be getting replaced with my bds long arm kit. Link to comment Share on other sites More sharing options...
johnj92131 Posted August 22, 2016 Author Share Posted August 22, 2016 On 8/22/2016 at 12:55 AM, Siopposition said: Where are you located? I have one that will be getting replaced with my bds long arm kit. Located in San Diego. But will be doing some cross country traveling in the next couple of weeks. You have a p.m. Link to comment Share on other sites More sharing options...
87Chief Posted August 22, 2016 Share Posted August 22, 2016 Do you know if a 4 cylinder 5 speed one will fit? If so I have one. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 22, 2016 Share Posted August 22, 2016 On 8/22/2016 at 3:44 PM, 87Chief said: Do you know if a 4 cylinder 5 speed one will fit? If so I have one. The cross member on all MJ's w. the 2.5 regardless of transmission is the same p/n as the 4.0 with the AW4 crossmember. So it's not the same as the crossmember for a 4.0MJ w. a 5-speed tranny. Link to comment Share on other sites More sharing options...
