WTB: Transmission support member for AX15
Where are you located? I have one that will be getting replaced with my bds long arm kit.
Located in San Diego.  But will be doing some cross country traveling in the next couple of weeks.  You have a p.m.
Do you know if a 4 cylinder 5 speed one will fit? If so I have one.
The cross member on all MJ's w. the 2.5 regardless of transmission is the same p/n as the 4.0 with the AW4 crossmember. So it's not the same as the crossmember for a 4.0MJ w. a 5-speed tranny.
