Whisslaren Posted August 15, 2016 Share Posted August 15, 2016 Hi!Finally getting back to my poor comanche. Got it started again after sitting for five years, so now I can drive it into the workshop under it´s own power. Feels good. Now to the question. I can´t quiet remember my exact plans for it, but I do know what parts I had gathered. I´ve been swimming through the tech writeups but it´s currently just making my head spin...I am changing to a 97+ front and fenders, but I also have the interior from a 97+. Can I upgrade the interior and make it work with my 88' wiring harness and driveline? Unless changing the dash, is there actually any huge advantage of changing the inside climate package?As you can probably tell from the above, I´m only interested in the estetics of the 97+. Driveline works fine so any major changes feels like it´s not motivated right now. Time is nothing I have a lot of. Also, will doors from a 97+ cherokee fit the comanche? Thanks/LW Link to comment Share on other sites More sharing options...
FrankTheDog Posted August 16, 2016 Share Posted August 16, 2016 To use 97 and up dash requires you to change to 97 and up electronics and major firewall mods. Stick with just the sheetmetal on the nose. Link to comment Share on other sites More sharing options...
mikekaz1 Posted August 16, 2016 Share Posted August 16, 2016 crank doors will bolt right on with only modifications to the striker pin. dash will not, like frank said, without long, detailed, indepth modification Link to comment Share on other sites More sharing options...
Whisslaren Posted August 16, 2016 Author Share Posted August 16, 2016 Okay, thanks guys. That saved me a lot of headache and time :-) Link to comment Share on other sites More sharing options...
