Minuit Posted August 15, 2016 Share Posted August 15, 2016 Here's an odd one. I need the grommet plug that plugs the hole for the automatic column shifter cable. It's an ~1-1/2" round grommet plug located at the very top driver side corner of the engine bay near where the clutch master cylinder would be on a manual truck. Should be found on floor shift auto and stick shift MJs - never seen it on an XJ. Anyone have one? The '91 very recently became a floor shift and the hole for the column shift cable is no longer relevant. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 15, 2016 Share Posted August 15, 2016 Why do you need a grommet since the cable's gone? Just get a 1-1/2" sheet metal or rubber hole plug. Link to comment Share on other sites More sharing options...
Minuit Posted August 15, 2016 Author Share Posted August 15, 2016 Want it to look factory. Although I suppose the correct term is "plug". I've been up for a while today. Link to comment Share on other sites More sharing options...
