airspeed Posted August 5, 2016 Share Posted August 5, 2016 I'm ready to mount the tranny to the motor. The new slave cylinder is compressed with plastic tabs, do I release those tabs prior to installing the tranny or do I just use the clutch pedal to break them loose after install? Link to comment Share on other sites More sharing options...
Eagle Posted August 5, 2016 Share Posted August 5, 2016 I'm pretty certain the FSM says to leave it compressed until after you have installed it and bled it. After bleeding, the first time you use the clutch will break the tabs. Link to comment Share on other sites More sharing options...
FrankTheDog Posted August 5, 2016 Share Posted August 5, 2016 In FSM and in Luk clutch instructions you leave the straps alone until it's time to step on the clutch. Link to comment Share on other sites More sharing options...
