I have a 88 mj with the one piece slave/ master. I want to switch to the 3 piece.
Can I just get one for a 95 yj with ax15 or am I going to run into diffrences needing one For x year cherokee.
as long as trans is the same your set. ie (external to external. internal to internal)
may have difference in firewall mounting holes, can be re drilled  to fit if needed.
i converted mine to a "3 peice" through Advanced Adapters
*edit*
yj has a difference length hydraulic line. only an issue if you plan to run the stock line. but with a "3 peice"  you have the option of putting your own in
