davedude Posted June 2, 2016 Posted June 2, 2016 Hello the Forum, I need the two hard lines from the master cylinder to the proportioning valve. The inverted flare fittings at the master are ruined. Kinda looks like I will have to make them up custom unless maybe someone has a source that I have so far been unable to find. I talked to a salvage yard who quoted me $100 with shipping. I can buy a roll of nickel copper line with fittings and a flare tool kit for less. The lines OD is 3/16, right? Thanks in advance for comments.
ComancheKid45 Posted June 2, 2016 Posted June 2, 2016 Yep 3/16 and custom is the only way to go afaik.
davedude Posted June 2, 2016 Author Posted June 2, 2016 Yep 3/16 and custom is the only way to go afaik. Custom it is then. Thank you sir!
