Strokermjcomanche Posted June 2, 2016 Share Posted June 2, 2016 88 swb with 3/2 metric ton springs in rear and 3.5 OME springs (2934) and shocks (60052L) up front . On some of the older threads I've read most if not all of the OME shocks like the N40L have been discontinued . With the truck sitting on the ground I have a measurement of 22 1/4 inches from stud to stud and I'm looking for the correct shock . I bought a pair of N190 shocks but the bushings are too small to fit over the shock mounts and aren't able to be changed . I'd prefer a bolt on shock so I don't run into this problem again, but if you are 100% sure they'll work I'll change bushings too . Thanks on advance . Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 2, 2016 Share Posted June 2, 2016 OME N40L (15.6"-25.8") Possible OME substitutes I know of:OME N30 (14.4"-24.3")* (96-05 Nissan Terrano R20) - I use these but you are 2" longer pin-to-pin than I am.OME N95 (14.13"-23.58") (Toyota Land Cruiser)OME 60002 (14.5"-23.1") (Toyota Land Cruiser)OME 60049L (14.4"-24.4") (Jeep TJ) These will work on the MJ but might be too short for you unless you can extend them a bit using something like the Currie bracket or similar below. Or call a Bilstein rep, give them the dimensions you need, and get their recommendations for a 5100 or 5125 series shock that will work. Link to comment Share on other sites More sharing options...
