Iowamike Posted May 6, 2016 Share Posted May 6, 2016 Ok so i put new bulbs in the cluster and a new headlight switchnan still no luck all so replaced the fuse any idea what to check next? Link to comment Share on other sites More sharing options...
gogmorgo Posted May 6, 2016 Share Posted May 6, 2016 Check the dash ground, covered in one of Cruiser's tips. Not to be a smartass, but you did make sure the dimmer isn't dimmed all the way? Link to comment Share on other sites More sharing options...
Iowamike Posted May 6, 2016 Author Share Posted May 6, 2016 Yes i triedmthendimmer in all directions and remdid the ground as well maybe its the cluster its self? Link to comment Share on other sites More sharing options...
Iowamike Posted May 6, 2016 Author Share Posted May 6, 2016 Went to the junk yard an all i cqn find is the clusters with the electric hook ups no actual speedo cabled ones. Link to comment Share on other sites More sharing options...
gogmorgo Posted May 6, 2016 Share Posted May 6, 2016 Is anything else in the dash not working, or just the lights? Link to comment Share on other sites More sharing options...
Iowamike Posted May 6, 2016 Author Share Posted May 6, 2016 I found a missing bulb socket in the cluster could that be it? Link to comment Share on other sites More sharing options...
Iowamike Posted May 6, 2016 Author Share Posted May 6, 2016 Just the night lights to see the gauges with out flicken a lighter. flashers an high beam lights work and temp oil an all the warning lights. Link to comment Share on other sites More sharing options...
Iowamike Posted May 6, 2016 Author Share Posted May 6, 2016 I think th3 temp works never seen it on I'm gona toss the temp sensor for a new one pretty soon. Link to comment Share on other sites More sharing options...
Iowamike Posted May 7, 2016 Author Share Posted May 7, 2016 I put the missing bulb socket in. It was for the battery light. I guess that was it because they now work not as bright as i thought 3 new bulbs would be but plenty enuff light an the dimer works. Link to comment Share on other sites More sharing options...
