daking Posted May 5, 2016 Share Posted May 5, 2016 Ive searched, and found some old threads, with dead links. I need to replace the window channel on my jeep. Any ideas where to buy? Link to comment Share on other sites More sharing options...
johnj92131 Posted May 5, 2016 Share Posted May 5, 2016 Did you check with your local Jeep dealer to see if the 97+ window felt is available? I would start there. After that, check your local pick and pull yard for samples of the window strips. If nothing else, it will help you identify the size of the felt you need. Rock Auto and the other auto supply stores should be able to help once you know the proper size felt you are looking for. Lastly, have you checked the Cherokee forums? How about the smaller AMC specific forums? I rather suspect the window felt you are looking for can be found in 80's GM cars. If so, after market GM suppliers will have the correct window felt. Link to comment Share on other sites More sharing options...
ScottJeep Posted May 7, 2016 Share Posted May 7, 2016 http://teamcherokee.com/front-door-window-channel-run-weatherstrip-jeep-cherokee-comanche-1984-1996/ Link to comment Share on other sites More sharing options...
