SlammedMJSlidin Posted April 26, 2016 Posted April 26, 2016 Could just be from old age or slamming into gears but my 4 speed sometimes has trouble going into second gear it always goes into gear just doesn't feel as butter as it should or like some of the other gears could I just need a flush or could I just be low on trans fluid?
benjy_26 Posted April 26, 2016 Posted April 26, 2016 Changing fluid would be my first step. What do you have in it as far as fluid goes? I personally have 10-30 synthetic motor oil and love the way mine shifts. Other guys use Redline MT90 and report having great results with it.
87Chief Posted May 2, 2016 Posted May 2, 2016 Should be a big bolt on either the passenger side or driver side of the transmission for the fill plug. Drain plug should be underneath the trans. https://www.google.com/search?q=ax-4+fluid+screws&biw=1440&bih=799&source=lnms&tbm=isch&sa=X&ved=0ahUKEwj2rIeR27vMAhXItoMKHdsGDmwQ_AUIBygC#tbm=isch&q=ax-4+transmission+fluid+screws&imgrc=mI4ZbyF-DKStOM%3A
