Scroll down to Post #4 by Eagle.  It lists the FSM bleeding procedure. http://comancheclub.com/topic/4647-brake-bleeding/
 I just went through the same headache with mine, and this system managed to get an air bubble out even after I put half a gallon of fluid through the system.  I also tied my load sensing valve arm in the vertical position to open it up all the way.   Give that a try and report back.
