Something I've never seen before
My truck is doing something wild, every so often, when I turn the key to the on position, it works like normal, when I start the engine, I could either put it in reverse or turn the heat on, and it turns the engine off. When it doesn't work normally there is nothing, no fuel pump, no radio, no dash lights, nothing. I checked the fuse box wiring harness, replaced some wires there, new ignition switch, starter relay and starter.
Hi Steven,
When everything is dead, do the headlights work?
If they do not, the problem is before the ignition switch.
If they do, then the problem is after the ignition switch. I suspect that will be the case.
Also, when it goes dead, what do you do then? Does it immediately come back to life, do you have to wait for a while, or do you do something to help?
Let us know!
Gene
