Angry_bucktooth Posted February 2, 2016 Share Posted February 2, 2016 Okay so I have a 1988 2.5l 4x4 (231) I just did the cluster swap and installed new senders so all gauges work. My problem is when I shift into 4wd I can hear it shift and feel it being engaged when I drive but my indicator light doesn't come on. I asked the guy who I got the cluster from if he knew wether the original vehicle had a 242 or 231 tcase he is unsure since he got it from a friend and installed it in his 2wd then he gave it to me. So any help as to why the light doesn't work. Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 Also I changed the bold to one that worked and installed a bulb in the full-time spot and neither come on when it's engaged Link to comment Share on other sites More sharing options...
gogmorgo Posted February 2, 2016 Share Posted February 2, 2016 The lights should work regardless of which tcase it came with, the cluster and wiring are the same down to where the tcase harness plugs into the main wiring harness. Is your CAD functional? On a CAD equipped model, the part-time light is triggered by the switch on the CAD, not by the tcase. If you locked the CAD, your light won't work. The wires are also somewhat exposed down there, so there's a chance they got caught on something and pulled out. That happened to me a long time ago and I decided it wasn't worth fixing, but then this summer I swapped in a 242, just plugged everything in the way it was for my 231 (minus the wires and vacuum going to the CAD... I swapped in a single-piece shaft) and to my surprise the part-time light was working again. Because on a 242 it's triggered by the tcase, not the CAD. But yeah, if you haven't locked your cad, check the wires running from the tcase to the front axle. Should be one orange and one black. Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 Thanks for the reply I'm gonna have to check for those wires I don't remember seeing them on the axle only the three vacuum lines and I have not locked my cad Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 So I went and looked and could not see any unconnected wires. Couldn't even see a spot they would connect to. I checked all around the cad and the rest of the axle Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 If it helps I have the indicator switch that is mounted on the passenger side fender with the blue cap. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 2, 2016 Share Posted February 2, 2016 They must have changed it for HO's I guess. Mine's a '91. I'll take a picture when I get home. But at any rate, the bulb should have constant power to the socket, and the switch opens/closes a path to ground, wherever it is. Here's the MJ electrical troubleshooting manual for '88. Should be something useful in there I hope. I'm at work now so can't dig too far into it. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 2, 2016 Share Posted February 2, 2016 Here's the switch I'm talking about. This is looking forwards at the back of the CAD on my '91. For reference you can see the upper control arm and mount just above it. I have no reason to believe this isn't the original axle, housing, but the truck had almost 300k miles in it by the time it got to me, so you never know. The hex nut looking thing is the switch, the round black piece sticking out of it is where the wires would go if they hadn't been torn off long long ago. Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 Yea I don't have that on my system I can try to get a picture of it tomorrow but it's a solid housing with no hex Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 https://www.google.com/search?q=cad+front+axle&client=ms-android-hms-tmobile-us&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiDlLSKltrKAhVDn4MKHTT8BcoQ_AUIBygB#tbm=isch&q=cad+front+axle+jeep+comanche&imgrc=5XAVhs4yoSGe5M%3A Not sure if the link will work but that's how my axle looks. Link to comment Share on other sites More sharing options...
Angry_bucktooth Posted February 2, 2016 Author Share Posted February 2, 2016 https://www.google.com/search?q=cad+front+axle&client=ms-android-hms-tmobile-us&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiDlLSKltrKAhVDn4MKHTT8BcoQ_AUIBygB#tbm=isch&q=4wd+indicator+lamp+switch+jeep+comanche&imgrc=nRMZ6kRVyXEI3M%3A And that's the indicator I have on my passenger side fender. Raining by me so used Google to get the images Link to comment Share on other sites More sharing options...
