Fuel rail/ regulator help
yes it is basically a rubber oring. A regulator that is faulty would cause extra pressure, but should not cause the oring to fail. Like any other synthetic rubber life span with gas and chemicals is not forever! However a good time to replace the oring and maybe the regulator. Make sure your orings on injectors are in good shape too. you can get them in a pack from most auto parts store!
