UNL1MTD Posted June 21, 2007 Share Posted June 21, 2007 I'm having problems using the Search, keep getting Debug errors. So I figured I would just ask. I want to replace the bulk of the vacuum hoses under the hood of my MJ. The ones on the evaporation canister are all but disintegrated. I did the CCV system which did a lot of the lines and helped out, but I would like to do the rest. Especailly since its listed as #1 to check for my current MJ problem ("Engine 'lopes' while idling or idles erratically"). So what size vacuum lines are used under the hood? About how many feet should I buy in order to replace the bulk of them. Only mention of size in the Haynes manual (that I can find) is 1/4" inside diameter when using it as a stethoscope. :nuts: Link to comment Share on other sites More sharing options...
kazzx Posted June 21, 2007 Share Posted June 21, 2007 I had to replace one i just used the extra clear tubing from my fish tank. Use that as a comparison. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 21, 2007 Share Posted June 21, 2007 dude, just take in the vacuum canister to the local parts store. compare sizes and get the right one, buy extra. Link to comment Share on other sites More sharing options...
