CSchumm88 Posted November 13, 2015 Share Posted November 13, 2015 hello i am new here i just picked up my first Comanche last night. It is a 1986 4x4 5 speed with a AMC 2.5L 5speed 4wd. i have good spark and it is getting fuel to at least cylinder 3 and 4 but i am not sure about 1 and 2. i can get it to run with starter fluid and will idle but vary ruff ( sounds like a tractor) the PO disconnected the EGR system. if i take the fuel relay out and crank it over it will fire whatever fuel is in the system and then die if i leave the relay in it will not fire and flood its self out really bad. any help would be great thank you. Link to comment Share on other sites More sharing options...
Pete M Posted November 14, 2015 Share Posted November 14, 2015 welcome to the club! :waving: since it is new to you, I would start with Cruiser's renix tips first: http://comancheclub.com/topic/48463-cruisers-mostly-renix-tips/ have you done a compression test yet? Link to comment Share on other sites More sharing options...
CSchumm88 Posted November 14, 2015 Author Share Posted November 14, 2015 it was a fuel injector and fuel regulator censer was just dumping fuel into the rear cylinders and flooding them before it could get spark in there. but thank you vary much for your reply. it run great now i have to fix the 4wd Link to comment Share on other sites More sharing options...
Pete M Posted November 14, 2015 Share Posted November 14, 2015 great to hear! :thumbsup: you should still run through the tips when you can. :yes: Link to comment Share on other sites More sharing options...
