hello i am new here i just picked up my first Comanche last night. It is a 1986 4x4 5 speed with a AMC 2.5L 5speed 4wd. i have good spark and it is getting fuel to at least cylinder 3 and 4 but i am not sure about 1 and 2. i can get it to run with starter fluid and will idle but vary ruff ( sounds like a tractor) the PO disconnected the EGR system. if i take the fuel relay out and crank it over it will fire whatever fuel is in the system and then die if i leave the relay in it will not fire and flood its self out really bad. any help would be great thank you.
