REEDracing94 Posted November 10, 2015 Share Posted November 10, 2015 Image Not Found Link to comment Share on other sites More sharing options...
REEDracing94 Posted November 10, 2015 Author Share Posted November 10, 2015 The plans is: 350/ th350/ Ford np205 9in / d44 Sticking with leafs for now Clayton 3 link front 40s if I can get the d44 shaft to survivr Internal 4 point Cage Etc. Hoping to keep it an all purpose rig. I have alot of buddy's that do dirt drags, so it will see that as well as trails and street. Hoping to get some boggers and run schuss mtn 2016. Picked up this thing for $500 last fall. Non running 2.5 and 2wd. Was planning on swapping in a 8.8, hp 30, ax15, and 231 and daily driving it. It sat for a few months and finally this spring I started messing with it. Turns out someone didn't know the firing order and had the wires all mixed up. Fixed it and gave it some ether and it fired right up. Found out quick it has a weak cylinder and pours oil out of every possible seal Still had to take it for a drive Image Not Found I picked up a 9in and HP d44 from a buddy for really cheap in the spring and decided to change the Comanche plans up a bit. Pulled the 44 apart it was full of mud and rust. A couple weeks ago I grabbed another 44 already set up for a jeep off of here. Also collected a th350 that needs a rebuild from elsewhere Last weekend I got the axles sitting in so I could Atleast see where it sits until I can afford the next steps. Being a 20 year old with too many projects means the budget is pretty low Image Not FoundImage Not FoundImage Not Found Pulled the carpet a couple weeks ago and found some nice custom floor windows as expected. Just more stuff to add to the list! Hoping to get the old motor and trans out soon and possibly pull my 350 from a buddy's parts truck soon First post shows how it sits now. Link to comment Share on other sites More sharing options...
A-man930 Posted November 11, 2015 Share Posted November 11, 2015 A dirt drag MJ would be first on here I believe... Do it! Link to comment Share on other sites More sharing options...
REEDracing94 Posted February 18, 2016 Author Share Posted February 18, 2016 Been lacking on updates, mainly because there hasn't been much. Less than 2 months until deadline, time to pull it into the barn. 3 link and new track bar ordered, motor is almost done, and trans is being tore down this weekend. Image Not Found Link to comment Share on other sites More sharing options...
REEDracing94 Posted March 10, 2016 Author Share Posted March 10, 2016 Link to comment Share on other sites More sharing options...
REEDracing94 Posted March 10, 2016 Author Share Posted March 10, 2016 [/urlImage Not Found Link to comment Share on other sites More sharing options...
