transmission question
It depends on what engine. The '86 MJ used only an AX-5 or (rarely) a T-5, with a small GM V-6 bellhousing bolt pattern. The 4.0L engines got either a Peugeot BA 10/5 or an AX-15 with a larger bell housing. If the Wrangler tranny is from a 4-cylinder it should work, but a 6-cylinder tranny won't fit your engine.
