why you shouldn't do excessive wheel spin
MancheKid86
here is a good example of why you shouldn't let your rig have excessive wheelspin!
friends rig
91 xj
5.5" short arm
4.0l/aw4 combo
open 8.8  rear
locked, trussed hp dana 30
35' tires
my friend took his rig out to a orv park thats just opened up for private club events only
first obstacle he got high centered and just gave er! way too much wheel spin
he ended up snapping his front axle shaft, so i went to my shop and grabbed him my cherokee's spare set
upon pulling his  drivers shaft, it was apparent that it wasn't a simple trail fix
his shaft was snapped into three pieces, one of which was still in the carrier and wasnt coming out
this weekend i had time to tear the axle apart to get the rest of his shaft out and this is what i found
snapped shaft, destroyed carrier, pinion gear and blown axle seal
so now i get the joy of  rebuilding  his front axle and upgrading his shafts to the newer bigger ujoint style
choose your pedal wisely, it took him two years of abuse to do it, but it will fail eventually, his splines were literally twisted alomst two splines over
Locker still good?
overall yes,
i had to cut the old carrier apart to get the locker out
the openings to where the lunchbox went were too mushroomed over to allow for the lunch box to nicely exit
one of the cups that house the end of the shafts from hitting the cross pin have a bit of the shoulder missing but otherwise no issues
have it installed into a new carrier and waiting till i bring him one of my spare gear sets to shim up into the axle
